Use this task to view TCP connections and UDP endpoints statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP/IPv6 Socket (TCP/UDP) tab.
IP/IPv6 Socket (TCP/UDP) Field Descriptions
Use the data in the following table to use the IP/IPv6 Socket (TCP/UDP) tab.
Name |
Description |
IPVersion |
Shows the IP address version as ipv4 or ipv6. |
Type |
Shows the connection type as tcp or udp. |
Index |
Shows the index ID for the connection. |
State |
Shows the link state for the connection. |
RecvQ |
Shows the connection received quanitity. |
| SendQ |
Shows the connection sent quantity. |
| LocalAddressAndPort |
Shows the local IP address and port. |
| PeerAddressAndPort |
Shows the peer IP address and port. |
